Mystery Washer part
Hi
After installing a clutch assembly on my whirlpool washing machine ,I noticed a part laying under the machine upon completion.Any help on what this piece is for would be appreciated.
See Attachment.
After seeing no response,I took washer apart again and noticed another one of these plastic tubes attached to washer frame with the pin loose inside with hole end pointed up. The pin is laying there not attached to anything.The part does not show up on any parts list I can find.
Thank You:
confused and still confused
Those are moving pins used when in transport. When it is delivered, the delivery people simply just pull on some straps and the pins fall in the cup.
Found the answer in another forum
