Neither Top nor Bottom Element Works - Electric Oven
Hey all, I have a Kenmore electric oven that has suddenly stopped working. The ranges on top, clock, everything works except for both the bottom bake heating element and the top broiler. When I try to turn the oven on there is an audible ‘click’ but nothing happens after that.
Any suggestions?
I’ve tried opening it up to look for a fuse box of some sort without an luck. I’ve removed the broiler element and was going to try putting a brand new one in. But I fear it might be something else because neither work?
Thanks in advance, Nick
Nick,
What is the complete model number of the range?
Hm, I’m not entirely sure. I no longer have the original paperwork. All I was able to find was a wiring schematic taped to the back which did not provide any model number. I’ll have to check around and see if I can find anything.
Also, due to my poking and prodding around while not exactly sure what I was doing, I’ve created a short somewhere. I can no longer throw the breaker without sparks flying out of the back. Might be time to call someone.
Hopefully the Model Number Locator will help you to find the model number, but if do not feel comfortable to work with a multimeter then it’s better to hire a pro.
