The led light on the motor blinks as it is suppose to. I turn on the washer and the shift disengages from the drive. So I have performed the field service mode test. It doesn’t agitate or spin. I disconnected the wires leading to the shift circuit and performed the test again. it still did not agitate or spin. That leaves the Inverter motor assembly, Yes?
Check to see if you are getting 120 to the motor via the dark blue wire in normal high speed mode.
