NO Drain Washer Whirlpool
I have an old top loader. It was working fine till now. I can open to lid before and watch the entire cycle. Fill ,drain.spin,. NOW the washer stops at the wash cycle ,NO spin,NO drain. Is it the drain pump? I cant see how the lid switch would cause this since before i could run the machine with the lid OPEN and it would work fine. Now tub full of dirty water HELP.:confused:
Since your lid switch was obviously not working, go ahead and replace it and see if that fixes your problem. If you havenโ€™t gotten the water out try bypassing the switch and see if that works. If not, you can take the drain hose out of the pipe and put it in a low bucket and the water should siphon out.
