No final spin
My washer cycles ok but does not do a final spin, even if you do a spin only. I have checked the door lock assembly, A-ok. Ihave checked motor resistance per wiring diagram, A-ok. Everything points to the motor control board, but it looks fine. Whuts up???
do you hear the motor
