I would appreciate any help of. Our dryer turns on and tumbles, but has no heat. We looked through the little peep hole and see no glow, or flame. We also checked the thermal fuse, thermal cut-off, and high limit thermostat with an ohm meter, it is reading all 3 are bad. Will those 3 elements being bad, cause the coils not to work? Should I be replacing those 3 elements and then the coils will work, or should I be replacing the coils first. Thanks for any help
If either one of those are open, the gas coils will not work. Did you make sure your meter is working by touching the probes together? There is an MOV (surge protector) across the wires at the burner harness connector. Unplug the connector and check continuity across the protector to make sure it’s not shorted.
Eric
