No hot water and replaced inlet valve
I have no cold water coming into the machine.
Hoses are good, water supply is good, screens are clean.
I just put a new water inlet valve in,as that seemed to be the general fix for this issue but it did nothing.
Still no cold water.
Anything else I can try?
Thank you!
Check if there is 120 VAC to the cold water solenoid while the control calls for cold water.
If there is no proper voltage, inspect the wires. If there is nothing wrong, replace the the water temperature control board.
  • The water temperature control board AP3175691
