When Hot temp is selected and the washer starts to fill, hot water comes into the machine for about 30 seconds then it clicks over to cold water.  The hot water never comes back on and I get a tub full of cold water.  I replaced the Valve Triple Water OEM (part number AP4412517) and the same thing continues to happen.  I was told it was likely the Water Temp Sensor.  Any other suggestions?  Is there a way to test the sensor before I replace the entire board?
              The sensor is not part of the control board, it fits into the water fill funnel. Are you filling the washer with the lid open? As a safety feature, most of these washers with electronic control will not switch from cold or warm to hot with the lid open.
GE WH12X10410 Probe Sensor Atc - AppliancePartsPros.com
Eric
              — Begin quote from fairbank56;833046
Eric
Thanks Eric.  I haven’t been opening the lid when filling.  I’ll try replacing the sensor.
