No Ice
I’m not getting the 120 volts to the coil that opens the valve to send water to the ice maker. The sensors in the frezer appear to be working correctly and the line is not froze as I can blow air through the line into the freezer. I checked the water in the door and when you put your glass in to get water it send a 120 volts to the coil to open the valve, this is not happening for the ice maker.
Gary
garyperkins said:
…The sensors in the frezer appear to be working correctly…
Gary,
How did you check them?
