Front loading Frigidaire (piece of junk) washer would only fill for 1-2 seconds then stop.Tested the pressure switch and it seemed bad. Replaced the switch and now I get nothing. HELP! Hoses and inlet are clean. Possible all valves are bad? Not likely. Any input is appreciated.:mad: Checked valves for voltage when it should be filling. None! Control panel? Replaced control panel and now its back to filling for 1-2 sec. then stops.
I am thinking door lock assembly and wiring, which is a weak link in these models.
Inside the lower service panel should be tech notes that will show you how to put it into diagnosis mode. See if that helps, otherwise go after the door lock.
