We recently got an older washer. It’s very nice, but it was leaking a bit. So I opened it up and replaced the clamps on the hoses. It stopped leaking for a bit, but then it became overly sensitive to being unbalanced. Anyhow I noticed when it is full of water and not running it leaks water again. I can’t figure out what is the sensor for unbalancing to adjust it. If I can’t fix it by adjusting it, I would like to bypass it. The leaking doesn’t seem to be a problem when it runs. but if it gets stopped midcycle it’s an issue. Obviously I’d like to fix the leak too, but if it’s something super complex I’d rather just deal with a small leak with a towel. It’s really only seems to be leaking when it get stopped from unbalancing full of water. So if anyone can tell me what is the sensor for unbalancing and how i could adjust it or bypass it, that would be great. Thank you
john
