Clothes are getting oil stains on them. Any ideas?
Unless the oil is from some oily clothes that you inadvertently put into the machine the stains are generally signs of the internal workings of the machine are failing. In this case a new washer is warranted, and if you got more than 10 years use from this model you deserve a new washer. It is a very troubled model and you have more than received your money’s worth.
