I replaced the RPS and am still getting the same ol error code. I noticed a single crack in the stator. Is there anything else I should check before replacing the stator? Thanks
Hello Boss377. There is a couple things to check for, on this model the inner tub is a floating tub design, you should be able to lift the lid,reach inside and the inner tub should lift up at least 3/8 of an inch. AP5306816So it will feel like its floating , or have some up and down movement,next I would remove the wash plateAP4316657 to see if there is anything underneath it a small piece of clothing,because the ol error is an overloaded code so something is making it think its overloaded, could be something in between the inner and outer tub, again some small pieces of clothing rags etc.Most of the time I will lean the unit back, to where I can see under it ,and take a good bright flashlite and you can see thru the outer tub, it is clear plastic, and usually you can see ,the small pieces of clothing slowing down the unit ,causing the error code. Thank you and good luck !
I checke the tub and it is free and clear of any debri, Could the stator be causing the problem?
Hello Boss377. Yes if the rotor is cracked thats the problem.
