Only Fillls with Water on Rinse
My top load GE wbse3120b2ww washer only fills with water on rinse. What i have to do is set it on rinse then after it is full set it to the desired wash cycle. Any suggestions?
Does it do this with temp set to cold/cold? Rinse is cold water only. Wash may be cold, warm or hot. Even the cold wash setting may mix hot water with the cold so you may have a problem with the hot water supply or the hot water valve solenoid. Switch the electrical connectors between the hot and cold valve solenoids and then try rinse fill. Do you get hot water?
Eric
The hot water supply is fine. The machine does this whether it is set on cold or hot. I can try switching the connectors to test your suggestion. I am hoping it is just the Water Inlet Valve (I think it has the solenoids on it) and not the Controls Asm board. Huge price difference for the parts.
