Out of Balance
I have read the post about the clutch being the problem with out of balance problems. I want to confirm before I started replacing parts.
After removing the front panel, I watched the machine run and the cloths constanting ended up in one place. Would rebalance the load or unbalance to the opposite side. Cloths ended up on the other side out of balance. It appeared that the one tumbler was running slow so I removed both and found a penny stuck in the tumbler. Put everything back together, tried again, same problem. To me it appears the tumblers are not working correctly and putting the clothes in one spot leaving them out of balance. Or am I totally off base and just need to replace the clutch?
Also it appears to me the tumbler are spinner backwards. Not sure how to explain but I would have thought the tumbler would lifted cloths up from 6 oclock and start the release at 12 oclock. The do not seem to agitate very well. I did confirm that they are installed correctly.
thanks,
