Greetings
RE: Maytag Glass top electric range
Model: MERH752CAS
Problem, oven was on, using one of the top elements.
Heard a lot pop, it blew the breaker.
Turned the breaker back on, burners still work,
But, the oven, broiler doesn’t turn on, clock doesn’t work, shows an: 88
None of the controls on the Electronic Control Board work.
I suspect a short some place.
The irony of the thing is that I replaced the broiler element (purchased from you) 4 days earlier and everything worked fine until the aforementioned problem.
Your thoughts?
