Oven/Broiler not lighting even after ignitor replacemet
[LEFT]My GE JGBP28GEL Oven and Broiler will not ignite. The display does not show any error codes. I replaced the oven ignitor but it still doesn’t light. I tested the voltage on the Electronic Oven Control (EOC) and it looks like there isn’t any voltage coming from the relay to the ignitor. I also noticed that there isn’t any voltage coming from the broiler relay to its ignitor. BTW, I tested each after turning the oven/broiler feature on to initiate the relay sequence. I tested continuity between the two terminals on the gas valve and it came back as closed (not infinity). I don’t believe this model has a thermal fuse so that rules that out.
[COLOR=#000000]
Is this an EOC problem? I also read that it could be an oven sensor issue but that is usually associated with a trouble code. Please help me troubleshoot this issue.
Thanks in advance,
[/COLOR][/LEFT]
Thanks guys! After testing all the connections and noticing that the timer switch was not passing power through the relays, I bit the bullet and sent the switch to be repaired. I installed it today and everything fired up! Now, I have a new ignitor and a repaired switch so it should last another 10 years. I appreciate all your efforts in helping me.
