Oven Does Not Get To Correct Temp
  I have Whirlpool Accubake System electric oven, the top works fine but  the oven doesn't achieve the correct heat. When set to 350 degrees it  only reaches approx. 250 -260.
I bought an oven thermometer to check it. To get to 350 or 400 I have to use BROIL not bake.
The Range was bought December 1999.
What is wrong? and what do I do about it?:confused:
Did the Bake heating element get red?
Yes it does but obvviously does not seem to get to the desired temp
Pull the range out of the wall. Remove the rear panel and check the oven temperature sensor for continuity. Normal reading at the room temperature suppose to be about 100 Ohms.
If the reading is incorrect, replace the oven sensor.
If the reading is correct then the problem is a bad control board. This part has been discontinued. In such situation it is time for a new range.
