Oven Doesn't Work
Hi,
My Stove, display and broiler work fine on my maytag electric range. But one day the oven just stopped working. When you go to bake you can hear the relays clicking in the controls but it will not heat up. I used the service manual to do the electronic quick test and it doesn’t display any fault codes, just cycles the relays. Does this mean the lower element went bad? It seems 5 years would be an awfully short life span.
Lee
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PER5750QCW
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16023323.pdf
Yes it could be blown. Remove it from the unit and check it with a meter.
Tech sheet says approximately 18 ohms.
Range model # PER5750QCW was working well when there were relay sounds clicking and the relay shut down. After checking the parts, the broil element does not have continuity. After replacing the blown up element, the display still does not work. What other parts should I look into to make the display work?
