My bake heating element stopped working so I ordered a replacement part. Prior to ordering the bake element I tested the broiler element and it was heating fine. The top burners were also working fine. I removed the old bake element in preparation for the new one. So just before the part arrived, my wife turned on the oven (by mistake) and she heard a “pop”. The bake element connecting wires were touching.
Needless to say after hearing the “pop” and installing the new bake element, neither this or the broiler worked. However the stovetop elements and control panel still work with clock, timer, temp etc. I took a look behind the oven and did not see anything unusual except for a little bit of black residue on the control panel. The residue was around the base of the black control panel part with a yellow “warning” label. This is also the part that the oven heating elements plug into. Am I to assume this portion of the control panel needs replacement? Or could this be anything else?
