I have the MMW5530DAW oven.
When day light changed a couple of weeks ago I notice that if I pressed the clock to reset it did not do anything. Then I notice that the numbers to set temperature some did not work. I notice that i can set the oven to Bake and set the temperature at 350 and it works great. I f i try to set the temperature to 325 i can set the 3 and the 5 but not the 2. I know that at least the clock, 1, 2, 7 I am in my office so do not know which others do not work.
I would like to know if: Part Number: AP4424899
Made by Whirlpool
is the right part to order.
Your problem could be either the control panel (Item 1 in Section 2) or the control board (Item 2 in Section 2). The usual way to troubleshoot is to check the keys with a meter if they check out OK then replace the control board first.
Still a bit of a crap shoot but your odds are better.
First find out what keys do not work as you can see the keys use certain tracks as common.
I would also try the following before ordering anything
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
