jennair downdraft gas range - keypad bad
On the key pad, the following numbers - 1-2-3-4-5-6 no longer work. numbers 7-8-9 and back-0-enter are working. This means that I cannot set the clock or the timer. I also cannot set the oven temperature for anything except 350 and 375. Any ideas?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JGS9900BDB
Here is the tech sheet
[http://www.servicematters.com/maytag_library/docs/16026923.pdf](http://www.servicematters.com/maytag_library/docs/16026925.pdf"]http://www.servicematters.com/maytag_library/docs/16026925.pdf[/URL]
Here is manual
[URL="http://www.servicematters.com/maytag_library/docs/16026923.pdf)
The non working keys you list all use track 2 as a common, problem ios so does "0" and you said this is OK.
The problem could be the control panel or the control board.
Check the control panel (keypad) with a meter
If it checks out OK then it is probably your control board.
Still a bit of a crap shoot but your odds are better.
Try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
I’m having the EXACT same problem with the same model. OP, if you’re still around how did you ultimately solve this? Did you have to get a new keypad?
