Everything works except the #9 and #0 on keypad do not respond
Is the problem in the keypad or the conrol board and is there an easy way to tell?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JES9860AAS
Here is a manual and a tech sheet
http://www.servicematters.com/maytag_library/docs/16025927.pdf
http://www.servicematters.com/maytag_library/docs/16025924.pdf
In the tech sheet you will see that both 9 and 0 use the same track #3 on the keypad’s ribbon cable. Odds are high that there is a problem with the ribbon cable.
You can check it with a meter.
Also you may want to try the following:
Unplug the unit
Open it up
Clean the edge connector.
