Oven won't bake
The top element in the oven only works for broiling. When I bake the bottom element heats up, but the top does not. The food remains raw on top and burned on the bottom. The keypad works fine and tells you when the oven is preheated so it does not detect a problem. Can this be repaired with a part replacement?
Your oven works as designed. The upper (Broil) heating element should work only when the Broil mode is chosen.
Put an oven thermometer in the middle of the oven and measure the temperature while the oven control calls for Bake and set for 350°F. Post the result.
Gene,
The thermometer read 300 when the oven stated the preheat was complete at 350.
Try to adjust the oven temperature as described on the page 16 in the "[AP2673398](http://shared.whirlpoolcorp.com/assets/pdfs/literature/74002570.pdf"]Owners manual[/URL]".
If it would not help then the control board has to be replaced.
Here are the break down diagrams for the Maytag range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=766715&&model_id=42219
Water inlet valve where the water supply comes in on the back may not be shutting off. Disconnect the line coming out of the inlet valve and try the water switch. Water should not leak here after you stop.
After much research I have come to the same end as well. The door glass has been discontinued by the manufacturer and no other replacements in any color have been made.
All you can do is keep calling around to see if anyone else has it left in their stock or take measurements to a company that makes tempered glass.
Wish there was more we could do for you.
Thank you for choosing AppliancePartsPros.com
Black Glass Have Totally Be Eliminated And Are Banned Here. I Dont Consider Them Suitable At All…
