Oven stopped working shortly after SELF CLEAN
Hello, first of all want to thank for this great web help and support. Having problem what lots of people do after SELF CLEANING on my Kitchen Aid KGRT607HBS9 gas oven. Everything looks as usually but oven does not work and constantly shows LOW for temperature reading. As I understand I have thermal fuse problem which is in the back of the appliance. Am I right and what is the number of the part I should be looking for? Once again thanks a lot for your help and time.
— Begin quote from zygis;568247
Hello, buttons beep and work as they used to- nothing unusual or suspicious only that gas is only supplied to the top/broil burner but not the bottom one. Is it possible that valve in the bottom storage compartment is not opening or some blown sensor not opening it because seems that only bottom burner is not operating properly. Thank you very much again for you effort and time. Thanks.
Zygis,
OK, Let me get this right, Everything is working and programming properly. The only issue is the bake burner won’t ignite, correct ?
You’ll need to remove the oven rack(s) and oven bottom panel to access the burner igniter. Program a Bake cycle and temp. and observe the ig niter. It should start to glow, and should be "white" hot in a matter of 30 to 60 seconds and the gas should release and ignite.
[part]AP3126125[/part]
If you have access to a "clamp on ammeter" you can check for a 3.2 to 3.6 amp draw on the igniter when it is glowing, or 3.2 to 3.6 VAC across the two wires that attach to the gas safety valve. If the amperage or the voltage is lower than specified, you have a weak igniter. If you have the proper amperage or voltage you’d have a bad oven burner safety valve, or no gas the the valve.
[part]AP3178816[/part]
