oven thinks its locked flashing codes
made the mistake of attempting to clean the oven on christmas eve nothing happened but now the lock light is on door will open but oven will not work lock is not engaged F8 code and alarm sounds disconnected power tried to reset no luck! pushed both upper and lower cancel buttons with no luck any ideas thanks for your help and have a merry christmas
NF means no fill, continuous fill of 12 mins. generates this. check water valves and hoses. if you do actually have proper water flow in and are getting this then check level sensor. a full tech sheet is avail at servicematters.com with info on checking components.
— Begin quote from Sue Brown;26243
:confused: Washer is just under 2 years old. During the wash cycle, the washer stops, and we get an error code of nF. Have checked the water lines and they are not clogged up. Called repair, can’t come for 1 week. Any help you can give me is appreciated. Tx
