Hello all,
I have a GE Washer that will start filling with hot (or warm) water for about a minute. After that the hot water shuts off as if it was full. However, at that point you can switch the water to warm or cold and it will fill up the rest of the way and cycle perfectly. If you just run cold water it works perfectly. It’s also not like the hot water doesn’t work at all. I’ve replaced the timer as it previously broke and the switch. Any ideas ? It’s an odd problem.
