Problems with Maytag Fridge
My refrigerator is not staying cool. I cleaned the coils as well as possible, checked the fan, compressor etc, all seems ok. I opened up the back of the freezer and the internal coils were all frozen up. i defrosted and everything worked fine. Week later same problem. I think the auto defroster is bad, but i cannot find the defrost timer, etc on this fridge to save my life. Any guidance please?
Here is a tech sheet and a manual
http://www.servicematters.com/maytag_library/docs/16025629.pdf
http://www.servicematters.com/maytag_library/docs/16026956.pdf
Try to force a defrost, see the tech sheet.
If the defrost element comes on then your defrost control board is toast.
If it does not come on, the easiest way is to use a meter and check the defrost element (30 ohms approximately) and the defrost thermostat (closed, 0 ohms when frozen, note it opens just above freezing)
If both check out OK then it is probably the board or you have a bad connection. Most likely the board.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Will do. Thanks for the info and manuals. Hopefully its a pretty easy fix.
How do you know for sure if the defrost is coming on? I forced a defrost on the fridge as suggested, and i think it turned on the defrost, but i am not 100% sure. before i spend $80 on the part, is there any way to guarantee that the defrost is coming on and the issue is the circuit board? Should I unload the freezer, take off the back panel and see if i can notice the defrost working?
Since you can force a defrost I would say that the board is toast.
Only way to tell for sure is to remove the evaporator coil cover, force a defrost and see if the heater comes on.
If it does the board is toast.
