Rear shell bearing for Frigidaire Front Loading Washer
— Begin quote from richappy;162057
If no roaring noise in spin and no excessive shaking, I would tip the washer back and check the belt AP4024823.
The belt is fine and it aggitates fine. If the load is a just a few thing it spins fine but when you put a heavier load in it tries but just cannot get going fast enough to spin out the water.
Any other ideas?
Release the top retaining clips with a putty knife, tilt up and remove front panel. Look for a lot of white plastic shavings on the bottom of frame and also look for water coming from the tub seal above the tranny.
— Begin quote from richappy;162063
No water coming from the unit and no white shavings. The unit is apart and the basket is removed.Is there a clutch in these units?The unit is about 12 years old, maybe older and i think that the clutch is slipping.I have looked at the schmatic but i don’t see a part for a clutch mech. If it’s built into the tranney it maybe time to buy a new washer.
Tip the washer back, remove the belt and turn the tranny pulley in the spin direction. The brakes should release and the tranny turn easily. If so, put the belt back on and start the washer in spin while holding the spin basket. If it is easy to hold the basket, you probably have a bad tranny clutch.
If so, I would re-post this as a possible bad clutch to confirm.
— Begin quote from richappy;162183
Thats exactly what is happening. Could a bad thrust bearing assembly be the cause or is it more likely the tranny clutch.
All the thrust bearing does is release the brakes. If the snubber is bad/ worn it will cause the clutch to slip.
— Begin quote from richappy;162253
If i spin the pulley by hand the the brake releases properly and the tub spins but if i put any pressure on the tub it stops spining quite easily and it feels like it is sliping somewere. Is this the tranny’s fault? By the way i do appreciate all the help so far.
If it is really easy to move the tub back and forth and the washer shook a lot in spin, you probably need a new snubber, a worn snubber will partially release the clutch.
ice maker jams, lot of ice, but will not fall down shoot
— Begin quote from lillquistg@bellsouth.net;249776
The ice maker or the ice dispenser?
The model number you posted does not come up. Verify and repost it please.
The Tub Will Spin The Agitater Will Not And There Is Aburn Smell
Hard to say exactly what with the limited info you have, but it could be the transmission hanging up.
Given the age of the machine, which I think is older than what you have indicated I recommend replacing it with a new, basic top loader. They have very good prices now.
