refrig and freezer are too cold
Even though I adjust dial controlls in frig it does not get any warmer. Both the frig and freezer are below freezing… What do I do? Also I can’t get the ice-maker to work. Is there something wrong with the thermostat?
Turn the freezer temperature control to warmer and warmer to see if it clicks off and stops the compressor from running. If it doesn’t except in the off position that will be your problem.
Do I need to replace the whole piece including the controls and the light? What is the part number and how do I get it?
I believe part 27 is your thermostat. Knob and freezer control. That is the only part you should need. This diagram of your control parts may help with disassembly. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140492
