Hoping for some expert guidance…
This fridge/freezer has been in my garage for the last 6 years. It gets cold out there and is right now, being winter… Anyway, a few weeks back we come back from the store to fill up the fridge with our goodies and notice a nice puddle of melted Popsicle on the floor. temps on the door are 80-90 and it couldn’t have been more than 50 degrees in the garage. I unplugged it to reset, no go. Went through the repair manual, diags give no errors. Load Operation check shows digit segments of COMP, Dispenser heater, F-fan low, R-Fan High, and Low temp mode.
Plug in fridge, the compressor relay clicks, compressor buzzes for a short bit, then relay clicks again. Repeats every couple of minutes. Then compressor is hot after an hour. The twin F and R fans are running. The compressor fan is not, but I suspect that is because ambient temp is between 40-50. I ohmed out the compressor wiring terminals. From common I get 2.45ohms on one side and 6.75 on the other.
Any help is greatly appreciated…
