refrigerator
:rolleyes: I have water seepage from air tower in freezer section that creates a thin sheet of ice in freezer bed and now seems to be leaking into frige. HELP!!!
Looks like the drain line is frozen up. Remove the rear panel in the freezer. Locate the drain hole in the drain pan (#7 on the [B]diagram[/B]) and defrost it using a hair dryer. Run hot water through the drain to make sure it’s open.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1309440&&model_id=5160953
Thank you for your prompt reply…We will try this first thing in the morning.:wink:
You are welcome. Keep us posted.
