How Do I Remove The Icemaker From A French Door Refrig. With Ice Maker In Top Left Corner Of Refrig. (after I Have Removed The Ice Bin With Auger)??
Gene:
Thanks For Replying. This Is A Maytag, But Apparrently Icemaker Is Made By Whirlpool. It Appears To Be On A Track Against Left Wall Of Refrig And There Is A Tab At Front Of Track Which Can Be Lifted To Release Icemaker, But There Is Something Else Holding It, Because It Doesn’t Bodge. Is There A Screw Somewhere Along The Bottom? I Can See A Hole In Bootom At The Rear Of Icemaker, But I Cannot Tell If There Is A Screw In Hole, Because It Is Recessed About An Inch And I Cannot Get My Finger In It. Cragin
Oh its that type of ice maker … Im sorry for the confussion and yes there is a screw on the bottom of the ice maker that will need to be removed before it will pull out … A 1/4 inch nut driver will remove it.
