I have to replace the shelf the enclosure that holds the freezer ice bin, auger motor, … How do I remove the yoke from the motor shaft?
It was probably not the correct way, but it worked.
I held the shaft with needle nose pliers and "tapped" the Yoke clockwise with a hammer and it came loose fine.
