Is it possible to buy/replace the tub bearing without buying the whole back half of the tub frame?
Normally on these front load units the bearing is factory machine pressed into the tub and not sold as a separate part.
I can only advise you to do an Internet search to see if you can find some company that sells the parts and sells or rents the tools to fix it.
System rejects my reply???
