Replaced Control Panel on Whirlpool Electric Range but there is nothing
The broiler element was not working on our oven. We determined that the contact switch for the broiler was not working, so ordered a new control panel. We have installed it, but there is nothing. The stovetop elements are working, but there seems to be no power in the control panel. Is there a reset switch or something that would start everything? There are only 6 wire to connect, so it doesn’t seem likely that it is hooked up wrong. Could the control panel be bad that we got?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=250261
See the attachment for the tech sheet/wiring diagram
[COLOR="DarkRed"]
We determined that the contact switch for the broiler was not working, so ordered a new control panel.[/COLOR]
I hope you checked the thermal fuse (Item 26 in Section 3) as that also will kill power to the broil element.
[COLOR="DarkRed"]
We have installed it, but there is nothing. The stove top elements are working, but there seems to be no power in the control panel.[/COLOR]
Do the stove top element indicator lights work.
If not then it sounds like a wiring problem (no Neutral)
All elements work off the full 240 volts but the lights and the control panel work off of only half the line, 120 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="DarkRed"]
Is there a reset switch or something that would start everything? [/COLOR]
No.
Yes.
Check the wires from the terminal strip to the control panel.
Since the old board was OK other than no broiler, reinstall it to see if there is a wiring problem
OR you could check for 120 volts between P4-1 and P4-3 (Neutral to L2), control board power, depending how comfortable you are messing with 240 volts.
What do we do now?
Call them and return it.
Does Appliance Parts Pro stand behind their parts?
Yes, they do.
