I was getting error code E6-F2 the first couple times I could reset breaker and oven would return to normal. Then it quit working so I was told to replace control panel, replaced control panel and it worked well for about 3 hours. Whats next:(
Unfortunately whoever told you to replace the control panel forgot to mention that there is a chance for the control board to be bad as well. It says in the manufacturer [Control panel parts replacement parts for WHIRLPOOL GBD307PDT09 | AppliancePartsPros.com](http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208302068.pdf"]tech sheet[/URL]: "Replace keypad" in step 2 and, then in step 3: "Replace the control" if the key pad did not solve the problem.
- The control board [part]AP3595759[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140641&diagram_id=951329)
