I have a portable GE dishwasher. It wasn’t draining and after reading on here and elsewhere it led me to the armature/solenoid. After replacing it, I can the unit and during the first "drain" cycle it drained. I had assumed it was working but this morning when I checked it there was water at the bottom of the unit again. I checked the armature again it is melted again!
I read in this thread that there might be an issue with the timer:
Can someone please guide me how to test the timer. Is there anything else that could be causing the brand new armature to melt again?
Also, this is a Canadian model. I can’t seem to find a schematic for it. This is the part I used to install:
http://www.appliancepartspros.com/ge-solenoid-assembly-wd21x10060-ap2039738.html
Just saw a warning now on another part suppliers website to look at the "timer" and replace it at the same time…Now I wish I had seen that before… someone else said they had the same problem, replaced and it burned out a few days later again.
Guess I want to make 100% sure the only reason it is burning out could be the timer… or, find a way to test the timer (Without the schematic I am not sure what it is). I haven’t flipped the unit down again as I need to bail out the water still.
