Replacing drum vanes
Instructions read
"To remove drum vane , "1.Insert screwdriver into center hole of the the drum vane and push the locking tabs open. 2. Slide the vane toward door opening to release tabs, and push on side of vane to remove."
I am unable to detect any locking tabs when pushing screwdriver through center hole. Is there a means to view (see) the backside of the drum when trying to reach the locking tabs? Can the upper cover be lifted? Is there a way to see drum from the back of the washer?
See if this service manual doesn’t help out.
Good luck, Happy Memorial Day!
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
Thanks for the assist. If this doesn’t show me, I doubt anything else would. Again thanks for the response
