Hello,
I have a Frigidaire Front Loader ATF8000FS1. I need to replace the agitator Vane part # (134509600). Can anyone tell me whatis involved to do this?
Thanks,
Dale
Hello,
Thanks,
Dale
I cannot get you model number to come up, please check and repost and I may then be able to link you to a repair manual that should explain what you need to do.
OK,
so the replacement is pretty easy.
Removal- Pull forward on the old Vane (towards the front of the front of the machine) The vane then pulls out.
Installation- Reversal of the removal except the new vane fits rather snugly. I used a towel and a rubber mallet to insert the vane into place. When I tried to insert the vane by hand i felt like I was "forcing it" and that the vane might possibly break. Anyhow one I tapped it a few time the vane slid right into place. My vane cam witha torx head screw to finish the install. Follow these instructions and the repair should take less than 10 minutes.
Regards,
Dale
Great, thanks for sharing that with everyone.
