My Frigiadaire front loader washer makes an load clanking noise while spinning. Upon my husband inspecting it, he found the one shock absorber was broken. For a bit under $40 we just ordered replacements (2 comes in a pack). Does anyone know how to change these absorbers? He said it looks pretty simple, but is wondering how the pins come out? Any help is greatly appreciated. Thanks!:o
In the middle of each pin is a keeper that need to be pressed in to allow the pin to be removed and the shock to come loose. If you have a deep well socket that will fit over the end of the pin, it can help with the removal. Other than that, wear gloves as everything is sharp inside those units.
