Roper dryer tumbles but does not put out any heat
Our Roper model RED 4440 SQ 0 dryer tumbles the clothes but it is not heating up.It is on the setting for heated dry.What might cause this ?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153033
See the attachment for the wiring diagram.
No heat can be a bunch of things.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Looking at the wiring diagram, the timer runs off of 240 volts when in timed dry. Put the unit to mid cycle timed dry. If the timer advances then you have 240 volts. Doing it this waay is safer than poking around 240 volts with a meter.
If OK
Next I would check the heating coil. They are usually 8 to 12 ohms.
If OK.
Check the thermal cut-off (Item 9 in Section 1). It should be 0 ohms.
If it is blown get post a reply as you have to find out why it blew.
If OK
Check the other thermostats. Both should be 0 ohms.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
