Roper dyer just stopped. Checked main fuse panel it didn’t trip. checked thermal fuse on blower housing it was good. Is there another fuse somewhere else i can check or what might be the problem. Dryer is only a year and half old. MODEL# RED444OVQ1
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5510056
See the attachment for the wiring diagram.
You could check the unit by unplugging it and setting the timer to mid-cycle timed dry with the door closed. Set your scale meter to about 200 ohms.
Now measure between Neutral and L1 at the power cord end.
It should be infinite ohms.
Push the start button and the resistance should drop to pretty well zero re: you should see the motor coil resistance about 2 ohms.
If it does then I would check the power.
An alternate method is to check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK then check the door switch and the push to start switch to see if they are closing.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
