Water leaking from under washer. I have been sopping up a large towels worth of water with each load. I leaned it back to get a look under and havn’t found the problem. HELP. I don’t know what to look for.:o
THANKS
Take off the cabinet and you should be able to see where the leak is coming from. Probably a broken hose.
This video will show you how to remove the cabinet.
