My washer of about 8 years will fill, agitate (although it sounds rough) and will drain but it will not spin. I have looked though all the advice online and I took the unit apart, removed the pump and motor and it appears (except for some wear) that the coupler is intact and not broken. Although I can not verify that since its apart. I took the agitator off to look for loose clothing or somthing stuck found nothing. I did not take the "c" clamp off the agitator not sure what else to do to check. Should the "drum" spin freely because mine does not. Should I take the "drum" out? If I do what am I looking for. What else should I try? can anyone help?
Related topics
Washer won't agitate or spin | 3 | 1352 | August 3, 2009 | |
Washer will not agitate or spin | 1 | 1478 | October 29, 2008 | |
washer wont spin or agitate | 4 | 1746 | February 25, 2010 | |
Washer won't agitate nor spin | 2 | 1630 | May 30, 2011 | |
Washer agitates, drains but not spin | 3 | 3068 | January 24, 2010 |
