selector knob replacement
I need to repace the program selector knob but do not know how to remove the front panel on the dryer; the owner’s manual does not show how to do this. Can you please give me some pointers?
To remove the top panel to access the control module & frame :
Carefully remove the two rear clips from cover by removing the T-20 Torx screws.
[LEFT]Carefully pry out the plastic covers over the screw on each front side of the dryer cover. Then, remove each T-20 Torx screw.[/LEFT]
[LEFT]When the front screws and the rear clips are removed, lift the white plastic top cover off of the dryer.[/LEFT]
[LEFT]To gain access to the top of dryer, remove the metal top cover by removing the seven T-20 Torx screws. Don’t forget to remove the screws in the two white plastic bumpers on front corners. [/LEFT]
[LEFT]To remove the fascia panel to access the display module & frame (for disassembly), carefully pry the panel toward front of the dryer and lift the panel up. Don’t break plastic tabs.
[LEFT]- The part number for the program selector knob is AP2805387 [/LEFT]
[LEFT]Gene.[/LEFT]
[/LEFT]
