Side by Side GE Refrigerator & Freezer Not Working
I have power to my refrigerator as the lights are one for both sides. However, niether the freezer nor the refrigerator are cooling. I removed the main electrical board and did see a small burn spot behind one of the larger components. I found the replacement board, but this board does not look exactly like the board that is currently on my refringerator. I was able to disconnect the "five white" wire connections from the old board, but can not seem to disconnect the last "blue" wire connection which is labeled "COMP-J8,DEFR-J9 & LINE-J11". The new mainboard (WR55X10552 part#) does not have a blue wire connection like this. In the same area, there is a green ground wire. Do I just cut the wires from the blue component to get the old electrical board off? What do I do with the exposed wires from this sense they do not seem to connect to the new board? Any assistance is greatly appreciated. Thanks again for your help.
Bernard in Atlanta, GA.
