[SIZE=2]washer cycle advances fine until very end never goes into normal spin speed just tumbles slowly for ever at 2min one hour later indicater goes to 1min at the end you have a load of wet clothes THANKS IN ADVANCE for any direction:confused:[/SIZE]
Look inside the lower service panel for a tech sheet. It will help diagnose the problem and put the machine into a diagnosis mode.
Look to the speed control board as a likely source of the problem, along with the wiring in the door lock assembly.
