Small brown marks on white cloths
The dryer is leaving small brown marks on mostly white cloths. I searched the internet and this seems to be a known issue with the front/back felt seals.
I was hoping someone could verify before I ordered the parts and if there is anything else I need to check.
Thanks in advance for any help you can give.
Kip
Kip
Yes, i would replace the front and the rear felt seals. They will come with some high temp adhesive. When you put them on, put the dryer back together, and let it sit for an hour so the seals will be fully dry. Tom http://www.applianceeducator.com/parts.htm
Thanks for the info. I will order the seals and give it at try.
Here are a couple videos that will help with the installation
http://appliancehelponline.com/dryerrearseal.html
http://appliancehelponline.com/dryerfrontseal.html
