I am new to all of this. I try to be handy with fixing appliances. Only work on my own stuff though. Anyways
I have a Frigidaire front load Washer LTF2140FS1. I was having the issue of it not dispensing the softener. The diverter unit was gunked up. So I researched and came to the conclusion that the solenoid/water valve assembly was bad. I just went ahead and replaced the whole unit to clear out both problems. While I had it apart, I pulled the big rubber boot out and the connector hose that goes from the dispenser unit down to the main "tub" and cleaned them all out. Which they needed it. Parts from here came very fast BTW!
I got it all back together and ran a couple cycles. Now, the issues I have are:
The softener will dispense and dilute the softener. But it now leaves the tray full of clear water.
The Bleach tray is now full of water after a cycle. Which it never did before. BTW, we have never used the bleach option so we have no idea how it worked before.
So this is where I am at. I have checked to make sure that the washer is level. I am looking for some troubleshooting options to try. I have a volt/ohm meter and know how to use it. So I can check to see if things are working if that could be issues. I only mention that so you know I am not totally green with working on things like this.
Sorry its such a long post. Just wanted to try to give as much info as I could. Any help or advice would be greatly appreciated
Dusty
